Bonsoir à tous,
Désolé pour la mise hors ligne un peu longue, le forum a été mis à jour ainsi que PHP (5.6 > 7.3) et MySQL.
Nouvelle version 4.4.1.
Un tout grand merci à @dj_ pour son assistance technique :-)
Les nouveautés :
Citation
Major New Features / Enhancements
  • Post Before Registering
  • Animated GIFs
  • AdminCP Notification Center
  • New Email Features:
    • Email Statistics
    • Email Advertisements
    • Unfollow Without Logging In
  • SEO Improvements:
    • Improved pagination with page number now in path (rather than query string) and unique page titles for paginated pages.
    • Improved use of canonical tags.
    • Improved handling of empty containers and profiles to reduce soft 404s.
    • Improved JSON-LD markup, adding @id tags and fixing URLs for comments.
    • Removed page output hidden by JavaScript.
  • Performance Improvements:
    • Added Lazy Loading for images, which will speed up page rendering.
    • Added HTTP/2 support with prefetch/preload.
    • Added support for Brotli compression.
    • Improved default profile photos to use inline SVGs rather than generated images, which will speed up page rendering.
    • Improved browser caching of pages served by the guest page cache, which will reduce the number of requests reaching the server.
    • Improved handing of session data for guests to reduce database reads for guests.
    • Optimized images to reduce file size for faster page rendering.
    • Other minor performance improvements to reduce database queries and fix unnecessary code execution.
  • Commerce Store Filters allow customers to filter products by price, review, stock, or custom admin-defined filters.
Core
  • Added setting to display user group formatting in more areas (see 6 New Micro Features).
  • Added less intrusive browser notification prompt in Notifications menu (see 6 New Micro Features).
  • Added ability to show sidebar blocks to only certain types of devices (see 6 New Micro Features).
  • Added ability for club owners to reorder the navigation tabs (see 6 New Micro Features).
  • Added ability for announcements to be linked to an URL or be a title only (see 6 New Micro Features), improved consistency in how announcements are shown in different areas.
  • Improved UI for entering time intervals in AdminCP settings (see 6 New Micro Features).
  • Added a new Icons & Logos section in the AdminCP which allows providing logos for use when sharing links from the community, adding the community as a home screen app on a mobile device (along with additional settings for a PWA manifest to control certain aspects the community’s behaviour when used in this way), and in Safari’s favourites menus and pinned tabs on macOS.
  • Added a new UI for attachments, showing a box with some information about the file, rather than a plain line (see Turbo charging loading speeds).
New Server Requirements: PHP 7.1.0 or higher required (7.3.x now supported). MySQL 5.5.3 or higher requires (5.6.2 recommended).
Removed Features
  • Removed EmojiOne-style emojis due to licensing issues.
  • Removed Gravatar support due to privacy concerns and performance issues.
  • Removed password hashes when downloading a member list from the AdminCP. This is for security, to reduce the ease of obtaining sensitive data if the AdminCP is ever compromised.
  • Removed the name of the content (e.g. topic) from the “Next Unread” link which could consume significant server resources on large communities.
[ Source : Invision ]
merci Nico , pour l'énergie que tu mets à nous permettre de nous exprimer,
et j'ai testé la censure automatique fonctionne toujours
"b..e" "put..n" 'salo..e" :p:
Arrêtez, je pisse dans ma culotte !
Tout est définitivement clair, maintenant...
Je suis un peu difficile, mais j'aurais préféré la version en roumain...
N'empêche, bonne lecture quand même !
To geek or not to geek, that's the question...
C'est un peu comme le format Boost. .. On ne comprend pas ce qui se passe!
En gros, rien de très disruptif  ( ^^ ) comme changement.
Quelques petites fonctions en moins que personne n'utilisait ici (gravatar)
Quelques fonctions en plus, certains qu'on utilise pas sur ce forum. d'autres oui.
Mais une amélioration de la vitesse et de la sécurité
il y a 31 minutes, Vincentw54 a dit :
cagoule® :-#
Suis tombé dessus en regardant pour configurer le forums,  j'étais certain que quelqu'un allait tester ^^
C'est la version pour néerlandophones?
Bien bossé les gars, j'y comprends que dalle aux changements mais j'aime bien le mot "disruptif".
Modifié par spin
Un beau montage bien cohérent, j'aurais mis un peu plus de php dans backend du kernel pour ma part.
Il y a 10 heures, spin a dit :
Pareil!
Il y a 17 heures, dj_ a dit :
Mince, je cherchais depuis hier ce mot !!!!
arf ^^    @nico  tu sais le supprimer?   il faut cliquer sur le premier thème,  il y a le thème testdj en dessous  (il hérite du premier)
Mais peut être laisser le thème par défaut comme thème alternatif
Modifié par dj_
Si il y a moyen de laisser le thème par défaut, moi je l'aime bien.
Les seuls thèmes une je vois c'est
- uniform - ipsfocus (default)
- testdj
Et testdj passe bien mieux sur un smartphone que l'autre.
Autre question : c'est qui "sujet" ?
Le thème "testdj" est le thème par défaut.
J'utilise Uniform même sur mobile, sur Android et iOS, depuis longtemps, et ça fonctionne parfaitement bien.
Juste une question, sur mon ordi certains derniers messages d'un sujet n'ont plus la date à laquelle ils ont étaient postés. Est-ce que c'est normal ? :omg_smile:
Euh t'es sûre de ça ?
C'est très bizarre comme problème.
il y a 51 minutes, dj_ a dit :
J'ai pareil
Perso sur mon tél j’ai le choix de thème :
- IPS default
- uniform (Défaut)
Non le soucis c'est a coté de "Posté"  normalement t'as la date ou le délais ( "il y a 5 heures")
Le thème testdj est supprimé et remplacé par le bon (le même mais avec son vrais nom)
Modifié par dj_
okay
Merci pour le taf les gars ! 👌
Ah, tiens, merci @nico pour les pièces jointes qu'on peut effacer par 25!
Pour un floodeur comme moi, ça simplifie la vie :)
Bon, après, ce sont des tonnes d'archives qui disparaissent à jamais et ça, c'est moche (et pas que pour moi) :-#
Ca bug pas mal depuis un petit temps au niveau des dates chez moi aussi.
Bizarre tout ça.
Je viens de faire une mise à jour, à voir.
Au fait, il y a des modifs au niveau du nombre de sujets qu'on peut suivre?
Perso je n'en ai plus que 5 ou 6... il ne me semble pas que je puisse en ajouter d'autres... ou alors c'est un plus ancien qui saute.
Il y a peut-être un paramètre à modifier?
Je vais regarder dans l'administration mais à ma connaissance pas de limites.
Depuis quelques jours, ma mise ne page est foireuse : le bouton "like" (des commentaires) n'est plus sur la page, je dois dérouler vers la gauche pour le voir apparaître (et il est pas tout près)...
J'ai rien changé à mon pc pourtant chef!
Essaie en vidant la mémoire cache de ton navigateur.
J'ai mis le thème à jour récemment.
Je reviens sur cette question...
J'avais ajouté des topics à suivre... ça a tenu un jour voire 2 mais c'est revenu à 5 sujets.
D'autres qui ont la blague?
Une chose me vient en tête... serait-ce un souci de synchro entre le poste au boulot et le poste à la maison?
Bon, je confirme que depuis hier j'ai 2 topics qui ont disparu da ma liste des suivis.
Pourtant je ne me suis pas connecté sur le pc de la maison hier soir...
