March 4, 201214 yr Ritchey WCS Wet black 100mm vissserie origine: 111gr Edited March 4, 201214 yr by mx_addict
March 30, 201313 yr Msc 31.6mm , 80mm Uploaded with ImageShack.us Edited March 30, 201313 yr by tooschae
November 25, 201312 yr Ritchey Axis 31,8mm 100mm (2014)122gr Edited November 25, 201312 yr by Stumpjumper
August 12, 201412 yr BBB UltraForce BHS-01 60mm - 31,8mm (2011) 111gr Edited November 23, 20196 yr by pascal68
September 25, 201412 yr PRO HI-COMP 2007, 100mm, 6°, 25.4, visserie standard: 172gr RITCHEY WCS ALU 4AXIS 2013, OS 31.8, 100mm, 6°: 113gr Edited September 25, 201412 yr by Matt
July 6, 20179 yr FSA SL-K MTB CSI Carbon 90mm 31.8mm -12° (vis acier). 124gr FSA SL-K MTB CSI Carbon 90mm 31.8mm -12° (vis titane) 114gr Edited October 1, 20197 yr by pascal68
October 1, 20197 yr SB3 Unicolor TR 100mm 31.8mm -10° (vis acier) 164gr SB3 Unicolor TR 100mm 31.8mm -10° (vis titane) 152gr Edited October 1, 20197 yr by pascal68
January 16, 20215 yr Lyti (+/- 17°) 70mm (Vis acier M4 donc non recommandé par Dulight de passer sur du titane) 79gr
September 15, 20215 yr SB3 Unicolor TR 80mm 31.8mm -10° (vis acier) 143gr SB3 Unicolor TR 80mm 31.8mm -10° (vis titane) 129gr
