Stumpjumper Posté(e) le 20 novembre 2023 Posté(e) le 20 novembre 2023 A vendre: 600€ Fourche Titane CEC - En parfait état #430T+ fork is a titanium fork for ultra adventure cycling requiring Boost Standard axle. Edge to edge welding combined to 3DTi technology increases the overall mechanical characteristics of the fork while offering premium aesthetic. Front and lateral stiffness have been optimised to deliver top of the range user experience for the most demanding ultra cyclist. Ready to rumble ! the #430T can fit all the accessories you can be thinking of for your next adventure !! The first thing you will notice, after its stunning look Of course, is the smooth "Velvet road touch" provided by our Titanium Magic technology. Material : Titanium Aerospace Grade #9, Brushed finish, Laser etched logo. Weight : 715g Steer tube type, length, ID : Tapered 1.5", L: 290 mm, ID: 25 mm Rake : 50 mm Axle to Crown : 430 mm Brake : Disc, Flat-mount, size: 140/160 mm Hub and Axle compatibility : 15 x 110 mm Thru Max Tyre Clearance : 700 x 2.5" (64mm) or 650b x 2.6" Crown Race diameter : 40 mm ( Use Slotted Crown Race ONLY ) Fork Cargo Weight Limit : Max 3kg per side using all 3 bolts Fender Mount : yes Front light Mount : yes Internal dynamo cable routing : yes, exit at top of crown or at top of the steer tube ( compatible with PLUG5 USB charger from CINQ ) Max rider Weight : 100 kg Accessories : Axle, Steerer tube expander and Alloy top cap, able port plug, Titanium T25 screws Compliant to ISO4210-2 : 2015 requirement ( test method : ISO4210-6 : 2015 ) 1
